? will puting a 3.73 in change my shift points alot
Old Jun 12, 2006 | 09:46 PM
rockholt454's Avatar
i just bought a 3.73 gear and havent installed it yet,when i do is it going to change my shift points when i put it in drive,if it is what is the best way to fix it.also it has a 2.73 in it now
Old Jun 12, 2006 | 10:16 PM
nonojoe66's Avatar
Re: ? will puting a 3.73 in change my shift points alot
it will change ur shift points in relation to mph but not rpm, i went from a 2:73 car to my new one with 3:73s all u gotta do is change the speedo. good luck wit them its gonna wake ur car up a little, mine chirps second now
Old Jun 12, 2006 | 10:27 PM
how do you change that
Old Jun 13, 2006 | 10:36 AM
nonojoe66's Avatar
im assuming u have a lt1 94-97, for my 94 i use a hypertech, u can use most hand held tuners, and i think you can buy a speedometer recalabration box or somthing im not sure
Old Jun 13, 2006 | 01:03 PM
TobyZ28's Avatar
My understanding is that even with the speedo properly calibrated it will need to shift earlier when going to bigger gears. This is because of a MPH/shift point table. Your gears are a bigger ratio, thus the desired MPH will at which you want the car to shift will be lower. You may want to modify the 1-2 shift table to stay in first a bit longer though, makes the car more responsive, instead of shifting to 2 before the car even gets going in normal driving
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
29
Mar 25, 2015 04:21 PM
