Reverse Lockout Code 83
Old Jun 10, 2006 | 04:14 AM
disco192's Avatar
So... car is a 1995 M6 w/ a 383 (not an M6 swap). It is a biach to get in reverse.
I know the reverse solenoid is not activating, hense the fighting reverse and the code.
My question is... is there any computer related problems that could cause this? I searched and found that a 94 tune can cause this problem. Im not sure when it started, but Im pretty sure it started when I put in the 383... I also got a new tune from Madwolf at that time.
How accessable is the solenoid? Can I test it easily or do I need to drop the tranny? Does anyone have any pictures of this?
Im gonna upload the stock tune to see if that fixes the problem.
Old Jun 10, 2006 | 08:00 AM
MEAN LT1's Avatar
Re: Reverse Lockout Code 83
The solenoid is very easy to get to. You may have to lower the tranny a little bit to take it off but it shouldnt be a problem.
Old Jun 10, 2006 | 08:16 AM
I can't imagine why the "tune" would affect the reliability of the reverse lockout solenoid. Its on the same fuse (#6 underhood) as many other items (skip shift, EVAP solenoid, EGR solenoid, fan relay) so if the fuse is blown, you should have a few other codes - worth checking the fuse. Or check the green wire on pin D6 to make sure its not loose.
Old Jun 11, 2006 | 12:34 PM
disco192's Avatar
THX guys...
Beave2780
Jul 7, 2015 06:36 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
Zone
Aug 2, 2002 04:36 PM
tbyrne
Jul 2, 2002 05:37 PM
