Rearend Fluid suggestions
Old Jun 8, 2006 | 07:45 AM
hey01's Avatar
96,000 on the car....always had to changed with normal fluid and GM limited slip additive.
Should I just keep going with what I always have?
On a side note, where is that ABS sensor on the rear end....is it easy to get too?
Old Jun 8, 2006 | 08:17 AM
nfa's Avatar
nfa
Re: Rearend Fluid suggestions
If by normal you mean conventional gear oil, I think you will be fine with that.
Old Jun 8, 2006 | 09:50 AM
01Z's Avatar
01Z
In fact, Auburn (which came in the 93 to 98) warns against using the synthetic....
http://www.auburngear.com/aftermarket/faq/#q2
Old Jun 8, 2006 | 10:54 AM
rskrause's Avatar
Moderator
Synth is a rear end is waste of money with one exception. The diff in a car that is road raced can get very hot and synth will tolerate high temps better. However, if it's a clutch type LSD, synth will likely be too slippery and interfere with proper operation.
Rich
Flint78
Jun 21, 2015 01:28 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
jmadoll
Mar 3, 2015 10:16 AM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
