reading Tunercat .bin need diag codes
Old Jun 7, 2006 | 11:45 PM
5.7LT1Formula's Avatar
i have downloaded the trial version of tunercats flashrom program. i have the *.bin file from my PCM but i can not get any of the other tunercat demo programs to open so i can view my trouble codes. Freescan used to work and now i get nothing, see freescan log below. i can email someone my bin file if they can tell me the trouble codes! before my only code that was throwing the SES light was my knock sensor. Put in a new sensor and tested everything 5 volts and the omhs are right. I was thinking maybe i needed to clear the codes out and start the engine back up. Any help would be great as i need to get my car back on the road ASAP!
(i do have a PCMforless tune coming for my new gears but i still need to see the trouble codes)
FREESCAN run log:
07 Jun 06 18:57:02 - Log file has started
Supervisor: CSupervisor- Com Port stopped
Supervisor: CSupervisor- Com Port restarted
P: 40 - Finding start header
P: 19 - Finding start header
P: 45 - Finding start header
P: 00 - Finding start header
P: 59 - Finding start header
P: 12 - Finding start header
P: 10 - Finding start header
P: 92 - Finding start header
P: a6 - Finding start header
P: f0 - Found main start header
P: From OnIdle - Idle Header Detected
P: *** Sending Shut-Up to ECU ***
07 Jun 06 18:57:11 - 0xF0 0x56 0xF4 0xC6
P: f4 - Header sent by ECU
P: Checksum Error - Not Parsing !!! **** !!! **** !!!
P: 5f - Finding start header
P: 01 - Finding start header
P: 02 - Finding start header
07 Jun 06 18:57:12 - 0xF0 0x56 0xF4 0xC6
HELP!
Old Jun 8, 2006 | 08:04 AM
Re: reading Tunercat .bin need diag codes
The .bin file is the programming. No trouble codes are stored in it.
Old Jun 8, 2006 | 11:46 AM
crap...well i will need to try again. Do you know which CATS program will work for scanning trouble codes? or any other that support a 95LT1?
Thanks again Shoebox!
Old Jun 9, 2006 | 10:31 PM
whitehooptie's Avatar
Freescan. It is free. No CATS program does that. Or TTS Datamaster. Free 20 uses or something.
lt1matt
Mar 21, 2015 07:35 PM
aj2494
Mar 12, 2015 10:17 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
