FrontTire Size - Should it be P275, P265, P255 or P245??
Old Jun 7, 2006 | 10:56 PM
No_Secrets's Avatar
Hey Guys,
I am looking at the Michelin Pilot Sport PS2 for my T/A. This is for the front of the car as I have Nitto 555R's on the back and they are P275 40 R17
http://www.tirerack.com/tires/tires....ilot+Sport+PS2
What I really want to know is what size I should get for the front. If I go with the P245 size I would lacking the overall width of tire but my handling should be better right? I like to drag race the car from time to time but need to know what tire size would be the best? When I say the "best" I mean for overall driving, handling and cornering.
Any thoughts?
Thanx,
Old Jun 7, 2006 | 11:01 PM
Re: FrontTire Size - Should it be P275, P265, P255 or P245??
Why do you feel a narrower front tire will produce better overall handling? The top-dog Auto-X guys will run 315's on all 4 corners.
Old Jun 7, 2006 | 11:05 PM
No_Secrets's Avatar
Injuneer said: "Why do you feel a narrower front tire will produce better overall handling? The top-dog Auto-X guys will run 315's on all 4 corners."
I am just thinking with the wider P275 tire it would be harder to control. The P245 tire is less likely of being squirly when you step on the gas. For corners I could see the P275 tires having an advantage over the P245's. Maybe I should go in the middle and get the P265's or P255's.
Old Jun 7, 2006 | 11:18 PM
Zack's Avatar
quit cheatin yourself. just get 275s
Old Jun 8, 2006 | 12:50 AM
eagleknight97's Avatar
Harder to control how? Its true that the 275's will follow ruts in the road a little more, but its not that bad. The 275's will be MUCH better in corners than 245's. Plus, another determining factor is the wheel width in the front...what is it?
Old Jun 8, 2006 | 07:23 AM
teke184's Avatar
"Plus, another determining factor is the wheel width in the front...what is it?
exactly...
and realize you need to find a match for overall diameter on the tire to be matched properly. just going from 245 to 255 to 265 doesn't mean the tire is just wider.
keep it simple stupid
8" wheel go with 245 tire
9 or 9.5" wheel go with 275 tire
Old Jun 8, 2006 | 07:48 AM
No_Secrets's Avatar
Thanks guys I will stick with the P275 size. I just wanted to be sure.
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
