Patriot Gold dual spring package
Old Jun 7, 2006 | 09:28 PM
hates rice 24's Avatar
i'm contemplating a cam swap, (probably something similar to tr224), but due to lack of cash, i have to keep the stock heads. I was thinking of changing the springs to the patriot gold dual springs. Is there any head modifications needed for these to work? I noticed that some of the other dual springs need some.
thanks for any advice
Old Jun 7, 2006 | 11:52 PM
GhostZ28's Avatar
Re: Patriot Gold dual spring package
I'm pretty sure they fit right in. I'll let you know next week when I get mine in the mail.
Old Jun 8, 2006 | 06:49 AM
teke184's Avatar
with only .56x lift...you probably don't need to get the duals. i would stick with the CC918s...they are good for a bit over .600" lift and are cheaper than the duals.
if your lift was closer to .600" i would say definatly do the duals.
Old Jun 8, 2006 | 07:18 AM
Greed4Speed's Avatar
For the price of 918's, you might as well get the Patriot golds and at teh least have the peace of mind of double springs. The Ti retainers will help with spring life and they'll flat last longer than 918's before needing to be replaced. If you get Ti retianers for the 918's you'll spend more $ than if you just got the PG kit. Plus you can benefit from the newer low profiles and run a 224-228 with more lift than the old TR224.
And the do drop right in. Patriot Golds are what I'm running. Cam is a 226/226 .590/.590 112
Old Jun 8, 2006 | 09:41 AM
GhostZ28's Avatar
Yeah with a cam like that, you should be able to go up to or maybe over 40k before changing springs.
R@mpage
Apr 20, 2015 10:02 AM
Red_94Formula
Jan 22, 2015 12:17 AM
Don 97 SS
Jul 11, 2005 08:50 AM
