Slip after change to Royal Purple .
Old Jun 4, 2006 | 10:35 AM
QUASARBLUEZ28's Avatar
Drained the rear yestersay and refilled with RP and GM additive. When I drove it today I noticed its slipping some when I crnak down on the gas. Noticed this in 3rd, 4th and 5th gears. It does grab but noticed the engine will rev about 500 rpm before it catches.
CLutch is a ST and thats been in about 6 months.
I never had this issue until I added the RP. Anyone else experience this?
Old Jun 4, 2006 | 11:38 AM
MyShibbyZ28's Avatar
Re: Slip after change to Royal Purple .
The rear axle? The rear axle will not cause slippage and higher rpm. If it was in your transmission I can see slippage happening. If you mean the posi slipping then sure, it could happen.
Old Jun 4, 2006 | 05:58 PM
After putting 150 miles on it on the highway the clutch slips in all 6 gears. I think it may be coinencedence in that that my Mcleod may need adjustment after serviceing the RE unit. There is no play at the top of the clutch, so I think I am leaving some clamping force on the table.
The clutch seems to be grabbing a lot higher than it was when I put it in now that I think about it. Its nice to have the the ability to adjust the MC with the ST without having to shim up the slave cyclinder.
I've got some clear coat drying on it now, so I'll adjust the MC in a day or 2.
Old Jun 6, 2006 | 07:02 AM
Found the Master Cylinder adjusting nut loose so I readjusted and tightened the MC to engage the clutch sooner off the floor.
No change on slippage. I plan to drain the Royal Purple gear oil and replace with non sythenic today after getting more additive.
I probably need not have had to add the friction modifier to the RP to begin with.
Old Jun 7, 2006 | 06:40 PM
Update:
Drained and saved the RP gear oil and replaced it with DYNO plus friction additive. Still slippage.
Put it on the lift today and shimmed the Slave maybe 3/16ths. This cured the problem but I expected the ST to not wear this fast (@4-5k miles non abusive).
Old Jun 7, 2006 | 10:20 PM
xpndbl3's Avatar
how would the rear end fluid EVER cause your clutch to slip? am I missing something here?
Old Jun 7, 2006 | 10:31 PM
Kinda what I was thinking. The rear end is solid. The only slipping possible in the rear end is the posi which would only make one wheel spin.
Old Jun 8, 2006 | 01:29 AM
wdtiger's Avatar
werd. There was no reason to change the rear end fluid to try and solve the slippage issue.
Old Jun 8, 2006 | 11:42 AM
MikeTR's Avatar
You have something going on with your clutch or hydraulics, NOTHING TO DO WITH THE REAR END. They are not related in any way.
Mike
Old Jun 8, 2006 | 02:30 PM
Coincidental is the bottom line.
Things were fine one day and not cool the next. There was a change made in between the slipping and non slipping event.
The Change was backed out as a logicial move even though things didn't make sense but the possibility the rear end had an issue did exist.
Old Jun 8, 2006 | 05:44 PM
No, there was no possibility.
Old Jun 8, 2006 | 09:51 PM
96flame's Avatar
If the clutch wasn't adjusted properly the whole time, then yeah it will wear out alot sooner. Hope thats not the case but sounds like it
Old Jun 9, 2006 | 11:16 AM
stik6shift93's Avatar
may also want to check your rear main seal to see if it's leaking.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Dmonty
Jun 2, 2015 11:19 PM
phantasm99
Aug 28, 2002 11:01 PM
