Question About Torque Converters
Old Jun 3, 2006 | 05:13 PM
Z28Vert19's Avatar
Probably a stupid questions but until i bought my camaro i never owned an Auto before so i really know nothing about them. Can someone explain to me what a stall will do for me (3000 RPM)? Also my car, as well as im sure most everyone else who has an A4, cruises at 80 mph and around 2100rpm's. will a stall affect this? if so how much and will it affect my gas mileage alot. I plan on driving my car about 800 miles from Virginia to Maine and on the highway my car gets about 25mpg right now. thanks for your time and input.
Old Jun 3, 2006 | 05:24 PM
user 647483's Avatar
Re: Question About Torque Converters
http://www.tciauto.com/tech_info/tor..._explained.htm
Hope this helps
Old Jun 3, 2006 | 05:36 PM
Z28Vert19's Avatar
thanks, keep it coming. id really like to here other peoples testimony of thier own experiences too. thanks
Old Jun 3, 2006 | 05:56 PM
etex95's Avatar
i have an a4 but 2100 rpm's = 60 mph for me with 3.23's. what gears do u have?
Old Jun 3, 2006 | 07:22 PM
Z28Vert19's Avatar
[EDIT] if i know if you have 3.23's than i guess i have 2.73s? But i am certain that at ABOUT 75-80 im at ABOUT 2100-2200 rpm's
Note from Moderator: Do not test or override the language filter.
Old Jun 3, 2006 | 07:50 PM
Z28Vert19's Avatar
What gears would I have? I just got the car so im not all that knowledgeable about the LT-1 and 4L60E or rear end
Old Jun 3, 2006 | 07:58 PM
Check the RPO codes in your glove box
GU2 Rear axle gear ratio 2.73
GU4 Rear axle gear ratio 3.08
GU5 Rear axle gear ratio 3.23
GU6 Rear axle gear ratio 3.42
Those are the 4 that apply to 4th gen Fbodies.
Old Jun 3, 2006 | 10:45 PM
Z28Vert19's Avatar
Yes sir, it has a 2.73, so if i change to a 3.73 im probably see a huge difference. The one question i still need answered is whether or not when im cruising is a 3000 rpm stall going to affect or not? Especially highway speeds (75-80)
Old Jun 3, 2006 | 10:57 PM
MyShibbyZ28's Avatar
3.73 will hurt your gas milage. You will cruise around 2200 or so at 65. If you get a 3000 stall with lock up it won't effect your highway miles, but will effect your city miles.
Old Jun 3, 2006 | 11:04 PM
Z28Vert19's Avatar
Thanks man i appreciate your help.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
