a4 question
Old Jun 3, 2006 | 02:54 PM
jay973's Avatar
a4 question
just wondering my car will not down shift past 55mph is this normal?
Old Jun 3, 2006 | 04:38 PM
n2ceptor's Avatar
Re: a4 question
What year A4???? Vehicle????? Does it have a down shift cable or controlled electronic??????
More info needed......
Old Jun 3, 2006 | 05:02 PM
jay973's Avatar
Re: a4 question
1993 camaro z28 cable
Old Jun 3, 2006 | 07:53 PM
n2ceptor's Avatar
Re: a4 question
Try this.... http://www.sallee-chevrolet.com/fram...ions/4L60.html
The Throttle Valve (“TV”) cable must be installed and adjusted correctly for proper transmission operation. The TV cable adjustment affects shift point, shift feel, detents, and downshifts.
Adjust the TV cable after the transmission has been installed in the vehicle. Adjustment of the TV cable must be made by rotating the throttle lever at the carburetor or throttle body. Do not use the accelerator pedal to rotate the throttle lever.
Stop engine.
Depress and hold down the metal re-adjustment tab at the engine end of the TV cable.
Move the slider until it stops against the fitting.
Release the re-adjustment tab.
Rotate the throttle lever to its full travel position.
The slider must move (ratchet) toward the lever when lever is rotated to its full travel position.
Check that the cable moves freely. The cable may appear to function properly when the engine is stopped and cold. Recheck after the engine is hot.
Road test the vehicle.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
