new torque
Old Jun 1, 2006 | 12:35 PM
camaro1fastz28's Avatar
Angry new torque
put new torque arm in the short one that mounts to the g-load brack and it adjustablale how to set it up baught it used and no instrections need help
Old Jun 2, 2006 | 10:11 PM
Red96Lt1's Avatar
Re: new torque
You will need one of those magnetic angle finders. You can get one from sears for less that $10. I believe autos are set to -1° to -2° and an M6 is set to -3° to -4°. Do a search to make sure that is right.
Old Jun 3, 2006 | 12:20 PM
Re: new torque
You don't want any more than -2deg for a street car, automatic or manual. For a "stockish" HP level, -1deg, for a big stroker -2deg. If you have enough HP to require more negative angle, set it there only at the track, return it to -2deg on the street. If you keep track of the number of turns of the adjuster nut, you can set and reset it for the street without worrying about the angle finder. But you have to set it up initially with the finder.
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
realistyc
Jul 28, 2015 07:32 PM
