Have some questions
Old May 29, 2006 | 06:01 PM
amc11890's Avatar
Have some questions
In a few months I will be purchasing a car and I pretty much want a trans Am, Camaro...etc(F-Body) Considering the Z28 or Trans Am. Wat is the difference between the LS1 and lt1 engine? Basically I want something fast and "sick sounding"
Im kinda clueless on this subject
Old May 29, 2006 | 08:23 PM
OBE1 95Z28's Avatar
Re: Have some questions
This link may answer some of your questions:
http://www.f-body.org/faq/4/index.htm
Old May 29, 2006 | 09:47 PM
amc11890's Avatar
Would a 2001 Pontiac trans AM have a LS1 engine?
Old May 29, 2006 | 10:02 PM
RussStang's Avatar
Originally Posted by Taintedz28
I have seens everal over the 300,000 mile amrk,
I have never seen any stock bottom end LT1 engines go anywhere near 300,000 miles.
where as LS1's rarely make it to 150
Who fed you this crock of sh*t?? Between a durability test, my money is on the LS1 lasting longer. I have seen LS1s over 150k. The only time I have ever heard of an LS1 breaking down was do to racing/abuse, or poor modifications. One of GM's parameters when building the LS1 was to build an engine that would address the weaknesses of the SBC and correct them.
LT1 engines make anywhere between 275-305 hp at the crank, depending on the model. Most LT1 cars dyno around 240rwhp bone stock, with the SLP cars dynoing alittle higher. LS1 cars were way underrated in hp by GM. The LS1 in any fbody is virtually identical to the LS1s found in the Vettes; LS1 fbody cars all make roughly 350hp at the motor, regardless of trim. LS1 cars are usually good for around 300rwhp stock, although the 01s and 02s can be good for 305-310rwhp, do the the LS6 intake manifold. All rwhp numbers are estimates for stick cars.
Old May 30, 2006 | 03:53 PM
2000GTP's Avatar
Yes, the LS1 was offered in the 98-02 f-bodies and it debuted in 1997 in the Corvette C5.
Old May 30, 2006 | 06:00 PM
2000GTP's Avatar
The LS1 is flat out faster, and a better, more refined engine. The LT1 however, can last a very very long time. I have seens everal over the 300,000 mile amrk, where as LS1's rarely make it to 150
Come to the midwest, there are plenty of LS1s over the 100K mark and they are running in the same condition as when they left the dealer lot.
Old May 30, 2006 | 06:50 PM
brians96Z's Avatar
I have a nice 1996 Z28 for sale, if you are interested. PM me for more info.
Old May 30, 2006 | 08:12 PM
amc11890's Avatar
this will be my first car. tell me one thing is a camaro/trans am a good started car or should i be looking at something else. I know the insurance will not be low, escpecially if i go for the v8 models and i know the mileage is prob not to hot but are the f-body cars easy to drive. Im a relatively good driver, right know i drive a navigator and a mountaneer. The one reason i was looking into the f-body cars is because they look awesome and they are relatively cheap for all the power you get.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
