Help:Changing Rod Bolts
Old May 29, 2006 | 03:19 PM
Black Cloud's Avatar
I've been told to change the LS1 rod bolts.How do I do this?I've heard one at a time but how do you retorque with ARP bolts?
John
Old May 29, 2006 | 04:02 PM
MachinistOne's Avatar
Re: Help:Changing Rod Bolts
I don't know how much those rods distort when changing to an ARP bolt, I usually throw them away and use Manley's on LSx builds.
Is the motor in the car? Do you have the rods on the bench?
Old May 29, 2006 | 04:04 PM
Still in the car.Help
Old May 29, 2006 | 05:02 PM
My worry would be distorting the big end bore...but they are a cracked cap design and so re-sizing is not possible.
Remove one cap and install new bearings, snug each bolt up tight, then torque to the specs supplied by ARP with the moly lube. Maybe lay some plastiguage in there to verify that the new bearings give you ok clearances. It's as simple as that.
Old May 29, 2006 | 06:21 PM
markinkc69z's Avatar
Why do you say resizing is not possible??
Old May 29, 2006 | 09:12 PM
In the traditional sense, resizing which involves cutting the cap and then re-honing the rod big end to spec is not possible with a cracked cap...there is no flat mating surface to machine. The only way to do it would be to hone the big end oversize and use bearings that are made for exactly that purpose. Like I said, I always use manley rods, so I don't even know if oversize bearings are availible.
Old May 29, 2006 | 11:07 PM
Thanks,John
Old May 30, 2006 | 09:28 PM
1racerdude's Avatar
I asked that question at Clevite and they didn't have oversize OD bearings as of 6 months ago.
Old May 31, 2006 | 02:10 AM
I'm pretty sure I saw that they are availible for the 4.6/5.4L fords, but same deal with those, I always use manley's as the reason for the motors being built in the first place is a ventilated block due to PM rods turning to shrapnel with the addition of boost or nos.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
