Question for HOBBS switch users...
Old May 21, 2006 | 01:24 PM
CALL911's Avatar
Where is everyone attaching their HOBBS switch to the intake? I have heard of getting a thick block off plate on the back of the intake and mounting it there. Is there anywhere else it will go or fit on the intake?
Old May 22, 2006 | 03:50 AM
ZBLKHELLRZR's Avatar
Re: Question for HOBBS switch users...
I'm using a T-fitting and running it off the driver side. I like that idea though. I may have to try that instead as that switch is rather big.
Old May 22, 2006 | 11:31 AM
davepl's Avatar
That's all I wound up doing as well. Actually, in my case, I had tossed the FMU so I mounted it in the FMU bracket and used the old FMU vacuum/boost line. Just pushed it over the sensor, clamped it on to be sure.
- Dave
Old May 22, 2006 | 12:43 PM
Fastbird93's Avatar
My question is WHICH block off plate??? The big one on the left (if looking at the manifold from the back side) or the smaller one on the right?
Old May 23, 2006 | 01:05 PM
blown383's Avatar
Just run a tee off of the brake booster line. Summit sells the part and I believe its a 1/2inch tee thats barbed on both ends with a 1/4npt female tapped into it.
-B
Old May 23, 2006 | 03:56 PM
Fastbird93's Avatar
-B
Hmmm..........yeah........not a shabby idea. Got a summit part number?
Old May 23, 2006 | 05:33 PM
blown383's Avatar
I'll dig it up for you once I get home.
-B
Old May 23, 2006 | 06:08 PM
Fastbird93's Avatar
-B
Rock on man. CALL911 and I thank you (we're both in the process of our builds).
Old May 23, 2006 | 06:30 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
They are usually used inline with the fuel system to detect a loss of pressure. I assume that you are using it on a turbo/blower car?
I would just install a pipe fitting "T" with one of the other vacuum lines
Old May 25, 2006 | 01:09 AM
blown383's Avatar
Here the part number is SUM-G1711
Picture:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG1711&N=115 &autoview=sku
-B
Old May 25, 2006 | 02:32 PM
Fastbird93's Avatar
Dude, you rock. I did a TON of searching on Summit yesterday and couldn't find that. Thanks man!
So what is the concensus here?? Just tap the brake booster line for the Hoobs switch reference to switch on the second pump??? Probably the least intrusive install, but is there any chance of it messing with the brakes?
Old May 25, 2006 | 03:08 PM
blown383's Avatar
I highly doubt that it would mess with the brakes... a HUGE lumpy cam would make you lose vaccum...not a little Hobbs switch.
-B
Old May 26, 2006 | 11:39 AM
will not effect your brakes.
Old May 26, 2006 | 12:10 PM
Fastbird93's Avatar
I just wanted to make sure that it wouldn't interfere with the vacuum flow on that booster line. I didn't think it would but never hurts to check. Thanks guys.
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
