HELP ! Changing tranny mount in driveway?
Old May 18, 2006 | 12:50 PM
S. Holley's Avatar
I have a 2000 SS T56
do you think it would be tricky to change out the tranny mount with just jack stands and a floor jack?? Or bite the 20.00-30.00 bullet and take it to lift.
Thanks for the help
Old May 18, 2006 | 01:23 PM
2001NBMZ28's Avatar
Re: HELP ! Changing tranny mount in driveway?
Shouldn't be a problem, save the $.
Old May 18, 2006 | 01:58 PM
valter's Avatar
http://www.installuniversity.com/ins...y_mount_m6.htm
Old May 18, 2006 | 02:11 PM
S. Holley's Avatar
Thanks VALTER
one problem... I have 2000 Camaro ?? what hell could be the difference in tranny mounts from other years? this is GM we are talking about?
Old May 18, 2006 | 02:19 PM
valter's Avatar
Originally Posted by S. Holley
Thanks VALTER
Should be exactly the same for a much wider number of GM vehicles and years
Old May 18, 2006 | 03:31 PM
GhostZ28's Avatar
ya after all, this is GM we're talking about
It shouldnt be a hard install, and you'l be very pleased on the comfort after.
Old May 18, 2006 | 06:38 PM
teke184's Avatar
it's cake to swap...
get the car on jack stands
put the jack under the trans
unbolt the trans mount from the crossmember
unbolt the 4 bolts holding the crossmember
unbolt the 4 bolts holding the mount to the trans
reverse
Old May 19, 2006 | 10:07 AM
Capn Pete's Avatar
I've changed it in about ~20 minutes or less on the garage floor .
Old May 19, 2006 | 08:47 PM
fbodyboy's Avatar
Did mine in about 20 minutes also in the transam. Its really simple and all fbodys since 3rd gen use the same mount.
Old May 21, 2006 | 04:17 AM
Bayer-Z28's Avatar
ditto.... Did mine when I replaced my Torque Arm and shifter...
mattszm6
Dec 14, 2014 07:09 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
