Logging wideband O2 output through PCM
I remember reading a while back about someone that had run a wide band O2 sensor through one of those Innovative LC-1 things, and then to the PCM. From what I remember he removed some useless sensor and used that for the O2 reading. Does anyone know what I'm talking about? Did it ever work?
It'd be really useful if this worked, so I wouldn't have to dick around with excel files and time scaling and time matching, etc.
Re: Logging wideband O2 output through PCM
For example, say you hooked the LC1 up to your throttle position sensor harness (don't do that though), your logged data would still read somewhere between 0 and 100 (%). If your scale is volts=0-5 for lambda=7.4-22.1, then a TPS reading of 0% means lambda=7.4 and a TPS reading of 100% means lambda=22.1. Then TPS%=50 means stoich, of course.
I don't know which sensor would be best to replace here though, it would obviously need to be one which normally gives a linear voltage output.
I seem to recall that whoever tried this before used an AC sensor wire that wasn't really important. The LC1 is totally programmable, so you can totally control the voltage range. I'm definitely going to pick this unit up, I can't see any good reason why this wouldn't work and to me it's 10x more valuable than other units that are essentially replacement data loggers.
I have an ALDL cable /w Datamaster. I know Datamaster won't support mapping the voltage to the correct AFR, but I'm pretty good with computers and won't have a problem patching the code.
I have a cable based on the elm322 chip (not sure about yours) and I have been able to use this software called wobd (link). It lets you design your own poll, decide which data you want to retrieve, and in some cases define the output units. You might be interested to check it out...
edit: now that I look at it again, I'm not sure that this would be useful in the way I was hoping... you can't change any of the predefined sensor outputs to raw voltage.
tommalcolm
Sep 11, 2015 03:39 PM
