fitting a 315 nitto on an 8.5" wheel?
Old May 12, 2006 | 10:11 AM
tfs95z28's Avatar
Just as the subject says, is this possible? I have gunmetal ZR1's all the way around, 8.5" width. Will there be a problem fitting a 315 nitto on them?
Old May 12, 2006 | 10:19 AM
Re: fitting a 315 nitto on an 8.5" wheel?
Is it "possible"..... sure. Is it "correct".... no.
There's an endless debate here on whether its a good idea to put the Nitto 315 DR's on a 9.0" or 9.5" wheel. For everyone who says its not a good idea to run a narrower wheel than the manufacturer recommends, someone will post that they've been running them on the narrower wheels and had "no problems". In reality, strictly in my personal opinion, it would not be a good idea to squeeze a tire that has a 12.13" wide section width on a wheel that is only 8.5" wide. Definitely going to look "bulgey" and like a too big tire on a too small wheel. But that's purely subjective.
Where did you find 17" "ZR-1" wheels that are only 8.5" wide?
4SFEDZ's Avatar
yes, it will go on, i dont think it will look good, and the contact patch you will have will be worse than a tire made to fit that size, 295 would be pushing it, that would be the absolute limit! 275 would be best!
Old May 12, 2006 | 12:03 PM
tfs95z28's Avatar
you know what... im an idiot... they are a 9.5" wheel. LOL, DOH!!!
The tires on it now are 275 40 17s, so will that work then?
I had a friend put 315's on the back of his car, dont remember what size rim he had, but it was so nice looking, tire went right to the edge of the fender. Made for a super aggressive stance.
Old May 12, 2006 | 01:18 PM
allblacksrt4's Avatar
but don't the nitto dr 315 say they fit a 9.5? i know the nitto's run small
Old May 12, 2006 | 01:21 PM
MonkeyBoneSS's Avatar
they do work, a few of my buddies are running the 315 nittos on thier stock wheels 17x9
Old May 12, 2006 | 01:34 PM
tfs95z28's Avatar
sweet... i gotta look into this. Ill do it, unless the contact patch wont be as large as a 275 Nitto because of the fitment...
Old May 12, 2006 | 02:45 PM
4SFEDZ's Avatar
ive ran 295 on a 9.5 and i think that looks the best and performes the best! jmo.
Old May 12, 2006 | 03:50 PM
OctaneZ28's Avatar
Disciple
I would not recommend putting a 315 on a 9.5" wheel. No way.
Yes, people do it, but that doesn't make it smart.
Follow the manufacturer's recommendations.
Old May 12, 2006 | 03:57 PM
haha rules were meant to be broken!!!!
Old May 12, 2006 | 04:01 PM
Donohue96M6Z28's Avatar
i wouldnt put a 315 on either... why dont you just buy 2 17x11 zr1's and do it the right way?
Old May 13, 2006 | 08:21 AM
The Nitto website does not show a mininum wheel width for that tire. They show that they measured it on a 10.5" wide wheel, and a maximum size of 12.0".
Old May 14, 2006 | 10:28 PM
neil350's Avatar
I have seen it done and it doesnt look good, the sidewall has to kinda curve inward to fit the rim, didnt look that great.
Old May 16, 2006 | 08:58 PM
slayer6x6's Avatar
NOT a good idea....
Old May 16, 2006 | 09:43 PM
thesoundandthefury's Avatar
On top of the safety concerns and the obvious excessive wear the tire is going to see, trying to fool people into thinking your wheels are bigger than they actually are just qualifies you as a poser. Don't do it.
