3800performance.com question
Old May 12, 2006 | 09:13 AM
billscamaro's Avatar
At 3800performance.com the have turbo kit for grand prixs and it says coming soon 1998-2002 v6 camaro. I was wondering will that kit work for my 1997 camaro??
Old May 12, 2006 | 03:07 PM
PaganEgyptian's Avatar
Post Re: 3800performance.com question
1997 models have different Intake designs, which are angled, starting in 98, they went to a straight intake design. 1999 is when they changed things around a lot more, such as drive by wire Throttle Bodies and 2000 is when they started using tubular Manifolds instead of the square cast iron. -Tim
Old May 13, 2006 | 10:06 AM
The kit would probably require you to take that stuff off anyway . My 1997 has a slp cold air intake so i would just need to take that off. It could be made to work couldnt it? Its not that much of a difference. Right?
Old May 13, 2006 | 09:10 PM
VladimirSteel's Avatar
hes talking about the actual intake manifold, but i guess you could swap it for the other maybe.
Old May 13, 2006 | 09:48 PM
jonny72888's Avatar
you could get it to work... but how much do you want to spend?
thats the thing, you could get your riding lawn mower to do a 9second run in the 1/4 mile if you have the money to build the motor.
Old May 14, 2006 | 01:35 AM
LTR450HQ.com's Avatar
Wrong, 1997 and 1998 both have the same intake and throttle body setups, in 1999 they went to straight throttle bodys, and in 2000 they went to tubular exhaust manifolds like you alreaday stated..
There's other turbo kits out there, in fact there's a used one for sale on camarov6.com right now, an FFF kit, go check it out.
Old May 20, 2006 | 10:02 AM
pcgamer4life's Avatar
Erm, actually I'm pretty sure that 97 was the last year for that style of intake. 98+ had the airbox on top, 97s are dipped down in the wheel well almost.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
