A/C only works for a while...
Old May 11, 2006 | 09:55 PM
Drowned's Avatar
I recently refilled my A/Cs gas after I had to empty it because of radiator removal... anyways, I filled it up, I reset my computer, it starts working, pressure is around 40 when on, so it works, but only for a while... Tt mostly stops working when I floor it but it will stop working after a while of normal driving too. The only way I can make it work is after reseting my computer again The worst part is that both my window motors are dead and it's rainy season, so I'm dying over here It was working perfectly before I emptied it
Old May 11, 2006 | 10:00 PM
Re: A/C only works for a while...
Did you pull a vacuum on the system before refilling it?
Old May 11, 2006 | 10:01 PM
Drowned's Avatar
No How do I do that?
Old May 11, 2006 | 10:03 PM
Drowned's Avatar
Nevermind, found it:
EVACUATING & RECHARGING THE SYSTEM
After the compressor has been installed and the hoses are reconnected, the A/C system must be thoroughly evacuated with a vacuum pump to pull out air and moisture. If not purged from the system, air will reduce cooling efficiency. Moisture will react with refrigerant oil and produce acids and sludge. Moisture can also freeze and plug the expansion valve causing noise, restrictions or a complete blockage.
A pump capable of achieving high vacuum must be used to pull out all of the contaminants. When air is pulled out of the system, it creates a vacuum that causes residual moisture to boil and evaporate. For this to occur, the vacuum pump must be capable of pulling at least 29 in. Hg of vacuum throughout the evacuation process (which normally takes about 30 minutes).
One of the best ways to monitor the evacuation process is with a Thermistor Vacuum Gauge that reads in microns (one inch of Mercury equals 25,400 microns). It takes a highly accurate instrument to measure vacuum because even a little pressure left in the system can prevent all the residual moisture from boiling out. Only a 1/2 inch of mercury of pressure (12,700 microns) can reduce the boiling point of water by more than 20° F. Pulling out the last fraction of an inch of pressure is the most critical step in the evacuation process to ensure complete removal of all air and moisture.
After you’ve pulled a deep vacuum on an A/C system, close all valves and shut off the vacuum pump. A slow rise in pressure (which you can see on the Thermistor Vacuum Gauge) will occur as the residual moisture continues to boil off inside the system. Pulling additional vacuum will get rid of this moisture. The evacuation will not be complete until the system can maintain a stable vacuum reading below 700 microns for at least three minutes.
The time it takes to completely evacuate an A/C system can be reduced by preconditioning the evaporator prior to hooking up the vacuum pump. Preconditioning raises the temperature so the moisture will boil off faster. The easiest way to raise the temperature of the evaporator is to run the engine with the heater on HOT in the RECIRC mode. Turn the blower fan to HI and close all doors and windows. When the engine reaches normal operating temperature, the evaporator will be thoroughly preheated and ready to evacuate.
If you have difficulty maintaining a stable deep vacuum, there may be a leak in the A/C system, the vacuum pump or the equipment connections. Leak testing should be done prior to evacuating the system because evacuation is not always a reliable way to locate or even identify a small leak in an A/C system. Seals and O-rings that leak under pressure may move under evacuation and not leak.
Finally, recharge the system with the recommended amount of refrigerant and compressor oil. Don’t overcharge and don’t add too much oil. Check cooling performance before returning the vehicle to the customer, to verify that everything is working properly and that the new compressor is doing its job.
Old May 11, 2006 | 10:50 PM
Detroit808's Avatar
I wonder if you're having the same problem as me.... I posted about a similar problem earlier today: "AC airflow dies on lowest setting"
HectorM52
Jun 23, 2016 08:42 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
