How important are heads on an FI setup?
Old May 8, 2006 | 08:28 AM
cjmatt's Avatar
I was just wondering if large ported heads really would make a difference when youre forcing in tons of air anyway. I was wondering if i could get away with a mild port, 1.6's and a decent cam and still make some sick power with some high boost.
Old May 8, 2006 | 10:24 AM
engineermike's Avatar
Re: How important are heads on an FI setup?
Can you make big power with stock heads? Yes. But, you can make bigger power with big heads.
Old May 8, 2006 | 10:54 AM
97WS6Pilot's Avatar
Yeh, the boost just increases the volumetric efficiency. So the more power you make NA the more you make Supercharged. The other consideration is low end torque. I went with a mild port to preserve the low end torque lt1's are known for. Mine is a street car though.
Old May 8, 2006 | 11:40 AM
Kraest's Avatar
Retired
If you're going with heads, get some bigger CC volume heads to lower your compression.
If you port your existing heads, you'll see a PSI decrease, but a power increase, which is good because there's less chance of detonation with lower boost.
Mike
Old May 8, 2006 | 02:05 PM
cjmatt's Avatar
well im getting an all forged 355 or 383, so i will just have it built for my desired compression ratio. I was just wondering if i needed to drop another 1500 on heads right now if i didnt need them
Old May 8, 2006 | 02:53 PM
Kraest's Avatar
Retired
I wouldn't worry about it if you're building a motor. Just turn up the boost if you get bored
Mike
Old May 8, 2006 | 08:32 PM
Roadie's Avatar
I think you are mistaken... The boost pressure lowers IN THE INTAKE because the heads were a flow restriction. This means more air in the cylinders, which equates to higher cylinder pressures, and more chance for detonation.
Old May 8, 2006 | 08:57 PM
97WS6Pilot's Avatar
You can get your porter to open up the bowls on lt1 heads so it lowers your compression. Just let them know what your application will be. You definately want to keep resurfacing to a minimum. I can't see spending $2000 for the AFR's. The blank trickflows are pretty reasonably priced and have bigger cc's.
Old May 10, 2006 | 10:57 PM
Flip94ta's Avatar
If money is a little tight toward the end of you build then get the cambers cleaned up and if any money is left over ask them to do a mild port job on the exhaust ports. The stock heads have a poor intake/exhaust ratio for Forced Induction. I think its 68% or so, 80% is optimum.
My heads were done this way on a tight budget, I had enough left to do a 3 angle valve job which is the next step in pay as you go hot rodding.
Also, if you dont have an intercooler yet get one before spending money on heads.
Old May 12, 2006 | 04:24 PM
Roadie's Avatar
Originally Posted by mgray
Can I also assume that you would have me believe adiabatic efficiency has nothing to do with a compressor-fed combustion process' predisposition towards detonation?
Of course the heat generated through lack of efficiency will aid in detonation, but "more power at less boost" isn't quite like getting a free lunch. You will certainly have more pressure in the combustion chamber.
In making the previous post, I did infer that Kraest's statement meant that you could up the pulleys back to the same boost level and still be safe. My bad... With the same size pulleys, you should be fine with a little tweaking of the timing and fuel tables. If it's a stock shortblock, I wouldn't go upping the boost back to what it was before the heads were done.
Old May 12, 2006 | 04:48 PM
LT1-TA's Avatar
PSI dont make power so much as CFM...
take poorly flowing heads and put 6 psi to them...
now take the same motor a nd put realy good heads on and 4 psi will make the same power and not be nearly as hard on the motor... heads area big deal.
Old May 13, 2006 | 04:04 PM
DvBoard's Avatar
as i understand it, heads aren't the most important part to FI, but once you get up there in horsepower they will become a resitricion in your system. to begin wiht though i'd focus on getting a good FI setup first.
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 08:12 PM
