4.3l Vortec
Old Apr 29, 2006 | 11:46 PM
strykermedic's Avatar
4.3l Vortec
Hey all, got a serious problem going on right now with my Blazer. I have a 96 Blazer i just had to repo from a guy, well when i picked it up I found that theree was over 15 quarts of water and oil in the engine. No wonder he didn't want to pay for it any more. I have had a similar problem before with a Ranger of mine, but I caught that rather quickly, the Blazer will not start at all now.
I am treating this as blown head gaskets. I know I need to get a compression tester this week to check the cylinders, but what other "simple" tests could I do to narrow it down? I am going to have the heads crack checked while they are off, I am willing to bet that atleast on is cracked.
Hey any help you guys can give me would be helpful. Gotta get this thing running so I can sell it. Thanks again.
Stryker
PS...Hey can any one tell me what the standard compression is on one of the motors, I am assuming between 120-130lbs, it has been so long since I did anything "mechanical"!
Old May 1, 2006 | 03:34 AM
jonathan_abilene's Avatar
Re: 4.3l Vortec
my 3.8L engine had a compression of 185-195 psi
is the oil yogurt looking? that would definately indicate coolant
in the oil.
dam wish I had a 4.3L vortec-head engine, even if it had a busted head gasket, thats easy to fix
Old May 1, 2006 | 09:01 AM
GRNcamaro's Avatar
Re: 4.3l Vortec
pressure check the cooling system. who knows maybe since the guy new it was geting repd he just dumped water in the engine
Old May 6, 2006 | 11:39 PM
Dave89IROC's Avatar
Re: 4.3l Vortec
head gaskets are not uncommon, but a more (extremely) common problem is the intake gaskets leaking coolant into the lifter valley
Old May 7, 2006 | 12:30 PM
Re: 4.3l Vortec
you know, after getting it apart this was the thought that I had, the heads looked alright, but I wasn't sure. So better safe than soory, took it all apart and going to get it back up and going next weekend. Of course I am going to take the heads in to get crack checked just in case, but they look suprisingly good. Worst part about the whole thing is all the damn wires. Man I cant get over how many wires there are under that hood!
Hal Fisher
Sep 30, 2015 09:03 PM
1995Blackz28
Jul 20, 2015 09:34 AM
dfarr67
Apr 10, 2015 07:44 PM
Chris Anderson
Jan 27, 2015 08:30 AM
SONOVISION
Classic Engine Tech
Sep 3, 2002 12:58 PM
