A/C Question inside
Old Apr 20, 2006 | 06:02 PM
playa7970's Avatar
A/C Question inside
I was wondering what sensors/relays are involved with the a/c system within a 94 z28 because about a week ago it started to blow hot air and the compressor doesnt engage any help would be great thanks
Old Apr 20, 2006 | 06:35 PM
2001NBMZ28's Avatar
Re: A/C Question inside
Might just be low on referigerant, there's a low pressure switch that will keep the compressor from coming on if that's the case. Look around at all the fittings for anything that looks like referigerant/oil might be leaking.
Old Apr 20, 2006 | 07:07 PM
playa7970's Avatar
hmm i had someone disconnect it and he tap into the low pressure switch and the car suddenly cut off it was weird any idea why it did that from what he says.... i dunno if i believe him but he said when he tapped into that wire that it engaged the clutch and if the bearings in the clutch are bad and its hard to spin the pulley the car will cut off is he right?
Old Apr 20, 2006 | 09:49 PM
playa7970's Avatar
bump
Old Apr 21, 2006 | 09:37 PM
playa7970's Avatar
nothing huh
jasonduaine
Mar 7, 2015 09:44 AM
grgguy
17
Feb 23, 2015 07:57 PM
alphaauto
Feb 5, 2015 05:25 PM
Deadbolt24
Jan 19, 2015 01:29 PM
pologreen97z
Dec 2, 2014 10:42 AM
