Who can help with an A/C Problem?
Old Apr 19, 2006 | 08:49 AM
ss00's Avatar
I need to add R-134 to my 2000 SS. In my '89 Camaro, I would pull the low pressure switch off of the accumulator and jump the terminals which would get the compressor spinning so I could suck in the R-12. On the 2000 SS, I can't find a low pressure switch anywhere on the low pressure side of the system. In these newer GM vehicles, what shuts off the 12V to the compressor when the R-134 charge is too low? How can I get the compressor spinning to add R-134?
Old Apr 19, 2006 | 11:22 AM
kallcium's Avatar
Re: Who can help with an A/C Problem?
When I added R-134 to my truck when the compressor was not spinning the pressure in the can was enough to send the refigerant in until the compressor had enough pressure to start spinniing and suck the rest in.
Old Apr 19, 2006 | 05:51 PM
Dave89IROC's Avatar
the n e wer ones use a transducer(sensor), not a pressure switch, so just hook the can up, if the pressure there is not enough, you will need to jump the relay
Old Apr 19, 2006 | 05:54 PM
ss00's Avatar
Thanks, Dave. Where might the relay be located, and how do I jump it?
Old Apr 19, 2006 | 07:05 PM
Dave89IROC's Avatar
the relay should be in the underhood fuse/relay box, and
it should be pinned like this
- <---jump this one
l-l
l <---to this one
- - if it is like this, jump them diaganally, if one way doesn't work, try the other 2 pins
Old Apr 20, 2006 | 07:22 AM
ss00's Avatar
Thanks, Dave. I really appreciate the information.
HectorM52
Jun 23, 2016 08:42 PM
HarleyZ28
Oct 5, 2015 06:23 AM
alphaauto
Feb 5, 2015 05:25 PM
Duke
Sep 3, 2002 02:48 PM
IROC5.7TPI
Aug 13, 2002 01:29 PM
