Widest wheel with manual rack
Old Apr 17, 2006 | 09:01 PM
Gearhead6s's Avatar
Anyone know what the widest front wheel I can run with my manual rack is? The stock wheels hit the tie rods.I hate the fact that I have to run skinnies with this rack but I didn't know it until after I installed it. Is it possible to have the stock wheels narrowed? I know you can have wheels widened but what about going the other way. I just want to keep it as safe ( i know its not anyway) as possible on the street and I don't want to ride on skinnies all day.
Old Apr 17, 2006 | 10:41 PM
Re: Widest wheel with manual rack
Yes, you can have stock wheels narrowed. A buddy of mine had a 30th SS convertible, and was running Grand Sport 17x11's in the back, and a 17x9" SS wheel, narrowed to about 6" wide on the front. Looked very good. Go to the WS6.com website... he has a link to a guy in Monrovia, CA that does the work..... that's also where my buddy had his done.
Old Apr 18, 2006 | 08:25 PM
Gearhead6s's Avatar
Do you know how wide I could go with a manual rack?
Old Apr 20, 2006 | 03:02 PM
93ZM6Tally's Avatar
I'm running 17x9 fronts, 275 40ZR17, with the Madman Manual Rack, and I rub at full lock, but only very slightly. I would say that an 17x8 would clear fine. I'd also warn you that turning a wide wheel with that box isn't exactly fun. Be better off with a much narrower tire/wheel combo up front. I'm thinking of getting my rims narrowed to 6".
Old Apr 25, 2006 | 08:30 PM
Gearhead6s's Avatar
So if i went with a 6" wide wheel i would be ok? i guess thats as long as its a 17" so that it clears the "ball joint' where the rack connects to the spindle
Old Apr 26, 2006 | 06:50 AM
93ZM6Tally's Avatar
From looking at mine I would think that a 6" wheel would work. I believe if you call them, (Madman/Thunder Racing), they'll tell you that this thing is designed for skinnies only, yet the warranty says that it's voided if the part is used for any type of racing.
Also when you do install it be sure to use Red Loctite on the bolts that connect the bump steer kit to the spindles. I literally had one come off while driving down the road, not a pleasant experience. Wore a nice little gouge down the inside of my rim.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
canbaufo
May 17, 2015 10:35 AM
cristian1311
Mar 4, 2015 04:45 PM
twistedwedge
Jul 27, 2002 01:54 PM
