wiring fbody fans up, what gauge?
Old Apr 16, 2006 | 08:37 PM
blown94's Avatar
Wondering what gauge wiring I should use for my fans from a fbody. Power and ground wires from battery to relay and switch to relay? Not sure what gauge I should be using for these? Thanks. Also if anyone knows offhand how the wiring should go to which posts and what relay Ill need that'd be great.
Old Apr 17, 2006 | 12:21 AM
smoknta's Avatar
Re: wiring fbody fans up, what gauge?
Just curious, buy why are you adding relays? Why dont you just use the stock ones? Unless this is not in an f-body.
Old Apr 17, 2006 | 09:36 PM
blown94's Avatar
Exactly. for an 89 1500 series. Got a 4.3 in it now. Im going to slowly start getting the accessories ready for the LT1 swap and figured this one can be done now. Gotta do the fuel system next. The fans are going to be run from the ignition switch for the trigger for now but when the swap happens ill wire them into the pcm. Anyways, for now im going to run a relay.
Old Apr 18, 2006 | 12:56 PM
Z28SORR's Avatar
Check the fan pig tail and use that gage for power and ground. Most likely 14ga. or 12ga. Relay switch is probably 16ga.
meissen
Jun 1, 2015 07:59 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
x7x7
Aug 15, 2002 06:49 PM
