quick!
Old Mar 24, 2006 | 01:30 AM
GoFast908Z's Avatar
Member
quick!
would there be any problems with running a JL 10W3 2 ohm with a JL 10W3 4 ohm off the same amp?
Old Mar 24, 2006 | 04:23 AM
LS1 RULZ's Avatar
Re: quick!
Yes. If you run them in parallel you get a 1.3 ohm load. Most amps can't handle an impedance that low. If you run them in series (or parallel) the 2 ohm sub will be getting twice as much power as the 4 ohm sub. This can be a problem if the subs share a common enclosure. I think it was Dave Navone that did an article several years ago about how it's not a good idea to mix and match sub-woofers like this. Even if each sub has it's own enclosure there is no guarantee that their outputs will combine together properly for good sound.
Old Mar 24, 2006 | 05:32 AM
wakebordr2006's Avatar
Re: quick!
yup...ls1rulz is right once again!
Old Mar 24, 2006 | 08:01 AM
GoFast908Z's Avatar
Member
Re: quick!
ok guys thanks
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
