If I were to shave the antenna...
Old Nov 4, 2002 | 08:50 PM
jeff94z28's Avatar
If I were to shave the antenna I can figure all the body work out but thats not the problem. I dont listen to the radio much so I dont care about clarity to much but occasionally I listen to it. Is there somewhere inside the car where I can mount one? Like some of the lux cars have them mounted on the back windshield?
Old Nov 4, 2002 | 09:10 PM
LS1 RULZ's Avatar
You can try mounting the antenna inside the B-pillar (sail panels). Just don't expect the reception to be very good there.
Old Nov 4, 2002 | 09:14 PM
jeff94z28's Avatar
Thats possible. Its not like I listen to it much but there has to be something better than that idea.
Thanks for the quick response I was thinking it would take a day or 2 for this.
Also anyone know what body work for something like that would be. They would probably weld in some metal and then bondo it right? Then a quick spray over the panel? Like 200 bucks? Just the body work not the stereo part.
Old Nov 4, 2002 | 09:40 PM
LS1 RULZ's Avatar
I think the B-pillar is about your only option really. It's about the only place in the car where you can mount the antenna vertically.
Personally I miss the old days when the antenna consisted of 2 wires embedded in the glass of the windshield. The cars I had with that type of antenna got much better reception than the mast antennas used today.
Old Nov 4, 2002 | 09:47 PM
jeff94z28's Avatar
I got an idea from a guy to use a VW antenna. One of the ones thats about 3 to 5 inchs tall. With that mounted in the spare tire Jack Area How would reception be. Or even inside the car. That would fit in a lot of places really easy.
Am I underestimating the body work?
Old Nov 5, 2002 | 07:46 AM
moparman's Avatar
I think you can still buy an antenna that is affixed to the windshield.
Old Nov 5, 2002 | 09:24 AM
LS1 RULZ's Avatar
I've seen ones like you mentioned that are "add-on" antennas and they looked like crap. The ones I was referring to were factory antennas inside the glass of the windshield.
Jeff,
What you could do is take a regular mast style antenna and temporarily install it inside the B-pillar just to see what kind of reception you get.
Old Nov 5, 2002 | 11:53 AM
jeff94z28's Avatar
I will try mounting it in b pillar this weekend. What do most people that shave the antenna do? Just not have a radio?
Old Nov 5, 2002 | 11:58 AM
LS1 RULZ's Avatar
I've never actually seen a shaved antenna. I HAVE seen what are called Frenched (I think) antennas. It's nothing more than a modified body panel that the antenna comes out of a contoured hole in the fender.
Old Nov 7, 2002 | 06:04 PM
z28m6's Avatar
nothing costs 200 bucks in bodywork world...prob like 500 , just a guess tho
Old Nov 7, 2002 | 06:15 PM
jeff94z28's Avatar
Yea I started thinking about the body work more and it will probably run 400 to 500.
Something Ill be thinking about long down the road when I need the scratch already on the panel fixed.
Old Nov 8, 2002 | 11:49 PM
AW/whiteZ-28's Avatar
Try searching for a powered antenna that just sits behind you radio it's a little black box i remember seeing it somewhere but i dont know where
Old Nov 9, 2002 | 11:07 AM
jeff94z28's Avatar
Maybe Ill just get a power antenna? Really cheap that way and it keeps it out of the way to a certain extent.
Old Nov 9, 2002 | 01:07 PM
bman555's Avatar
You can get an amplified antenna, which is about 5 inches long and replace your stock antenna. You can alos get antennas that will attach to the back window.
I think the power antenna is a good idea, i might be doing the same thing.
Old Nov 9, 2002 | 03:19 PM
Musix's Avatar
I've had a Hirschmann power antenna ever since I bought the car. Looks good and if I ever need the radio, which is almost never, the reception is still there.
PCLZ28
Dec 24, 2015 05:19 PM
Bobczar
Oct 23, 2015 11:22 AM
Chuck2
Apr 16, 2003 09:04 PM
FormerPony
Oct 12, 2002 12:14 AM
No4nRice
Oct 9, 2002 07:38 PM
