Need Gen7 wiring help
Old Mar 19, 2006 | 04:53 PM
N20Dave's Avatar
I am trying to identify the black wire that comes out of the 8 pin ignition harness and is labeled as "G". It is has two female connectors and appears to go to nothing. The scematic in Calmap suggests that it is some kind of ground yet my application does not appear to use it. Any help with what I should or should not do with this wire would be appreciated. Thanks
Dave
Old Mar 21, 2006 | 06:53 AM
aDFIguy's Avatar
Re: Need Gen7 wiring help
That wire is the shielding for your cam/crank position sensor inputs. Connect it to any chassis or frame ground point and you should be fine.
Old Mar 21, 2006 | 05:47 PM
N20Dave's Avatar
Thanks.
Old Mar 21, 2006 | 06:13 PM
MEAN LT1's Avatar
Now lets see some videos of the car running under it own power.
Old Mar 21, 2006 | 09:33 PM
N20Dave's Avatar
It's real close...
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
