Hogh Pitched Noise Coming From LS1 Engine
Old Mar 18, 2006 | 08:22 PM
CAMAROZ28AQUINO's Avatar
I just bought a 1998 camaro z28 ls1 and when its running a high pitched noise is soming from a part of the engine, not the engine itself but one of the parts attatched to it. Any ideas?
Old Mar 18, 2006 | 08:36 PM
2001NBMZ28's Avatar
Re: Hogh Pitched Noise Coming From LS1 Engine
Probably just the air pump - does it stop after a couple minutes, only on cold starts?
Old Mar 19, 2006 | 08:35 AM
if i leave the car idling it stays but if i take it for a ride its gone.
Old Mar 19, 2006 | 12:29 PM
2001NBMZ28's Avatar
Might be something else then. To see if it's the pump pull the "AIR PUMP" fuse while it's making the noise, that will immediately disable it. Be careful, use insulated needle nose plyers, mines a small 30 AMP fuse under the hood.
Old Mar 20, 2006 | 08:22 PM
firebreathingta's Avatar
Does it do it all the time. I think I have the same problem. Its kind of sound like a popping sound, high pitched. I just figured it was because I installed a new lid. Because it doesnt do it all the time, and when it does, it stop after a short drive.
I have a 2000 camaro ss.
Old Mar 24, 2006 | 07:03 PM
cmaro's Avatar
Im hearin the same thing on my 2002 but its still under warranty so ill take it in when the weather gets better and let you know.
Old Mar 24, 2006 | 09:27 PM
jimih941's Avatar
Its most likely the AIR pump. It whines at start up and under heavy load.. it pushes cool fresh air into ur exhaust manifold.. its basically for your cats and for emission. Its not a bad noise... my friends who drive mustangs (enough said) make fun of me calling it a supercharger. You can remove the whole pump, its basically under your driver side head lamp check. I forget the site but there is site with instruction for removal... but remember that this noise is healthy for your car and removing it will set off codes and burn up your cats.
Old Mar 24, 2006 | 09:37 PM
Chris-Go-Fast's Avatar
you also might wanna check the alternator pulley, sometimes it loses tension and it whines/squeaks.
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
ChrisFrez
Nov 23, 2014 10:33 AM
StngStlkr
Sep 6, 2002 05:47 PM
