low buck bottle bracket
Old Mar 18, 2006 | 06:01 PM
nfa's Avatar
nfa
I was looking around home depot for a piece of sheet aluminum to use to fab up my own bottle bracket to mount in my rear passenger seat for easy access. Didnt find anything there, so I had to improvise:
I had a computer that I was throwing out, and it turns out that the top part of the box is the exact same width as rear seat cushion bracket (HAHAHA). Drilled some holes into the ghetto bracket, painted it, then bolted it in. Still need to bolt in the backside, but it doesnt look half IMHO.
Old Mar 18, 2006 | 06:11 PM
camaroKid223's Avatar
Re: low buck bottle bracket
looks great!
Old Mar 18, 2006 | 09:34 PM
TMoNeE98's Avatar
truth, it does look good.
Old Mar 19, 2006 | 11:04 AM
nfa's Avatar
nfa
thanks guys!
Old Mar 19, 2006 | 01:07 PM
00Z28SS's Avatar
I like that alot. Nice work.
Old Mar 19, 2006 | 01:11 PM
nfa's Avatar
nfa
btw. if anyone else is considering putting their bottle in this location, there is a pre-exising hole in the floor pan in a convenient location to put your blowdown tube. Just pop the grommet out and drill it to allow the tube to go through.
Old Mar 19, 2006 | 03:34 PM
Fuels94TA's Avatar
Looks great....wow a 94 with clean carpet.
Old Mar 19, 2006 | 09:59 PM
Well done.
There is a bracket from Nitrous Outlet/Nitro Dave that mounts on the tunnel, between the seats:
http://www.nitrousoutlet.com/catalog...product_id=984
Old Mar 28, 2006 | 05:57 PM
transamzex's Avatar
Looks great! Now if you can just get by the tech guys to let you race with it in the back seat! Or is a blow down tube all that is required when it is in the back seat?
Old Mar 28, 2006 | 07:58 PM
Fuels94TA's Avatar
Yes, it can be mounted there as long it has a blow off tube exiting the cabin
Old Mar 28, 2006 | 10:10 PM
nfa's Avatar
nfa
i have a blow down tube.... i just didnt take a picture of it. it just so happens that there is a factory grommet that is positioned perfectly for the blow down tube to go down so no drilling required. I made one small slit in the carpet for the tube to pass through.
Old Mar 29, 2006 | 03:06 PM
There is no rule against having the bottle inside the passenger compartment (which it already is when its in the hatch area) as long as you have a blowdown tube.
Old Mar 31, 2006 | 01:45 AM
johnny3986's Avatar
How many inches is that blow down tube? I am mounting my bottle on the hump, but I have no clue if a standard blow down tube will work for me or not.
Old Mar 31, 2006 | 09:30 AM
You can shorten the blowdown tube, or you can use an -8AN braided SS line, with a bulkhead fitting in the floor.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
alphaauto
Jan 23, 2015 07:42 AM
LVZ2881
Aug 27, 2002 08:35 PM
taner
Aug 23, 2002 05:25 PM
