A4 to M6 Swap & Car Won't Start
Old Mar 15, 2006 | 05:54 PM
Sweetred95ta's Avatar
The starter won't even turn over, so I think it has to do one of the wires I unplugged from the stock shifter (Only starts in P or N). I'm going to go dig a little bit and see if I can't figure it out. I appreciate any help.
Benji
Old Mar 15, 2006 | 06:08 PM
rngilliland's Avatar
Re: A4 to M6 Swap & Car Won't Start
There are six wires on the connector to the switch on the auto shifter. The two thickest ones (should be the top two) are for the neutral safety switch. Connect them together and the starter should work. If you plan to use the neutral safety switch on the clutch pedal just extend those two wires to the switch. I would recommend using the switch. It can save you embarasment
if you forget to press the clutch before starting.
Old Mar 15, 2006 | 07:12 PM
Thank you. I knew that I needed to connect two of the wires, but I didn't know which ones. I just plugged that plug back into my stock shifter so I could start it. I appreciate it.
Benji
Britbilly
Jan 7, 2015 08:49 PM
Ricardo
Nov 29, 2014 10:58 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
