wheel well rust?
Old Feb 26, 2006 | 02:36 PM
Gr95camaro
Guest
Posts: n/a
wheel well rust?
hey i have a 95 chevy camaro the car has 125,000 miles on it the car is in excelent shape all over thought then engine compartment is clean the interior has no rips or stains people tell me the car looks more like a 30-40 mile car but my wheel wells not that any one noticed it is rusting i plan on taking it to a shop and having them fixed this summer. the undercoating bubbled up in to these blisters and when i took a screw driver and poked them they poped and rust fell out any one else have this problem?
Old Feb 26, 2006 | 02:44 PM
2000GTP's Avatar
Re: wheel well rust?
My whole car is pretty clean, which is surprising because I bought the car from somebody who was a Chicago resident. My old third gen though was in the opposite shape as the wheel wells and the floorboards were rotted out pretty badly. The cost to repair that stuff outweighed my motivation to further keep the car.
Old Feb 26, 2006 | 02:52 PM
Gr95camaro
Guest
Posts: n/a
well my floor boards are fine its just the wheel wellsjust where it was undercoated
Old Feb 26, 2006 | 03:25 PM
amean94ta's Avatar
wow weird i have had rusty 3rd gens but never saw a 4th gen with rust yet anyway chips dents and scratches yes rust nope
Old Feb 26, 2006 | 03:40 PM
Gr95camaro
Guest
Posts: n/a
car was never in an accident and like i said wierd part about it is its emaculate i have see other 95 camaro but never with an intior as clean as minei have a light tan intior and not one stain in it not a single rip or mark and on very verly ninor scratches and and on small small ding. i plan on have the wheel wells fixed im just wondering how much its gona runn me i dont really want to spend more then 2 g to have them fixed
Old Feb 26, 2006 | 05:00 PM
amean94ta's Avatar
my guess is $1,200 with fading the paint in and new under coat on both sides
Old Feb 26, 2006 | 05:33 PM
Hawk's Avatar
for the under body parts that are rusted, try this stuff. Used it on my truck works great.
www.por15.com
Old Feb 27, 2006 | 03:53 PM
TraceZ's Avatar
I would recommend getting a wire wheel on a drill and cleaning up the rust to get an idea of how bad it is. Is it on the surface, or is it a hole in the metal?
Por15 is great stuff. If the rust is only on the surface I'd recommend cleaning it up, painting it with Por15 and applying fresh undercoat on it.
Old Feb 28, 2006 | 02:59 PM
Gr95camaro
Guest
Posts: n/a
beat you to that i did clean it up i sand blasted some and wire brushed some other parts of it the driver side wheel well is just rust the pasanger side has a whole in around the bottom. i dont want the car to get out of control so i really insist on replaceing them in the next year or two becuase i plan on keeping the car for a long long time
Old Feb 28, 2006 | 04:25 PM
TraceZ's Avatar
I hate to be the bearer of bad news, but if you have a rust hole in one place, and surface rust in other places it is pretty much over for your car in the long term. It is going to rust to oblivion. All the little seams and welds. It's already started in all those places you cant even see.
Trying to stay on top of it will cost you more over the years than you can stomach. In another 5 years your car will be looking really rough.
Sorry, but it's a ticking time bomb. As cheap as completely rust free 4th gen cars are today, it might not ba a bad idea to trade it in on a rust free car and not have to worry about it any more.
Old Feb 28, 2006 | 07:14 PM
Gr95camaro
Guest
Posts: n/a
little jumpin the gun arnt you not seeing the car and all? i know the car and there is no rust any where else i have had the car on the lift looking at every thing. i think this is just a problem with the undercoating either not being applied properly or a deffect in the undercoating becuase the car is spotless every were else even has been garage keeped in the winter since i have bought it and the previouse owener older gentelman the same. like i said this is a by product haing something to do with the undercoating and im gona fix it. i have resored other cars and know what to look for. i curiouse on howmany other camaros are having this problem i would have never found it except i was doing some maintnace on the breaks and noticed something thats when i took a screw driver to the undercoating other wise i would have never found it . the best way for me to descibe it is like blisteres but not very visible. but i will have them fix im going to get a quot in a few weeks.
Old Feb 28, 2006 | 09:42 PM
TraceZ's Avatar
You are right, I was making some assumptions. I assumed it was winter driven. I assumed it was the typical 10 winters build up of rot finally making holes. Now that you describe it in greater detail it does sound repairable.
Let us know how it goes.
The thing that bothers me the most about welding in patches is the back side. What if the structure of the car does not allow access to the back side of the repair? How do you go about making sure it gets painted/protected so it does not just rust through again right away? There are lots of little nooks and crannys in our cars making it hard or impossible to get to the back sides of panels.
Old Mar 1, 2006 | 07:59 AM
Gr95camaro
Guest
Posts: n/a
you know i did weld in pannels in my truck cab conner on an extanded cab and i had just that problem. we used weldable primer that was 4 to 5 years ago and the new cab conners are still good. the reason im not welding the wheel wels my self are first in the process of moving but most of all the car is a unibody and i dont want to cut the wheel wells out and get distortion in the body and im not sure if they would it apears to me by looking at it thought that it is just a sheet metal covering becuase there is more sheet metal right behing it. i have replaced floor pans and a trunk pan in a 70 chevelle but then the car was guted and i could well in structuall support. i figure ill just leave this to the professionalls thanks guys ill let you know how i make out
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
shroyvin56
Apr 3, 2015 08:15 AM
CaRParts102
Dec 6, 2014 08:45 AM
