confusing 70 nova ss starter problem!!!please help!!!!
Old Feb 26, 2006 | 11:44 AM
88GTAbandit's Avatar
ok so i installed a high torque mini starter on my girlfriends 70 nova ss. the car has a 350 4 speed w/ 11:1 compression and a mild cam...the original starter had only 1/4 of its impellor touching the fly wheel, and had no shims on it...so we bought a new high torque starter for it..the difference between the 2 are that the original(mini starter) was like a standard starter where the impeller is covered and has opening for flywheel contact...but the new one did not have this hood. the impeller already sticking out..so now the problem...after installing the new starter w/o shims, when you go to turn it over, it is not making contact with the flywheel at all...it is just free spinning.....its lined up in the correct holes and cant really be adjusted(except to change positon of the motor and solinoid)..also the flywheel appears to be fine and have no damage to the teeth..so i am confused, there were 2 shims that came with the starter, but i figured buy installing them it would just make the impeller farther away from the flywheel....please help if have any info....i'm stuck
fustrated and confused
dave
Old Feb 27, 2006 | 12:55 AM
Re: confusing 70 nova ss starter problem!!!please help!!!!
problem solved, just used other mounting holes and machined the aluminum mounting bracket down abit..
dave
Old Feb 27, 2006 | 11:19 AM
Z28SORR's Avatar
Chevy has two different diameter flywheels. You had the wrong starter for the flywheel or the wrong flywheel for the starter.
Old Mar 3, 2006 | 03:44 AM
damien8618's Avatar
were there any 350 blocks that came with both bolt patterns, staggered and aligned?
Old Mar 3, 2006 | 08:11 PM
firebird69racer's Avatar
they all are
Wade
AlaskaZ28
Apr 17, 2015 08:54 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
