Turbo 350 swap question
Old Nov 3, 2002 | 03:11 PM
sseeya's Avatar
I have a 93 Z/28 that I'm building for bracket racing. I'm using a Turbo 350 trans. I have a Spohn Torque arm so that's not a problem, but the stock crossmember and tranny mount does not line up. I could have sworn I read somewhere that the stock A4 crossmember from the 4L60e would work with a Turbo 350. Was the 700R4 crossmember different from the 4L60e? Am I missing something else?
Old Nov 3, 2002 | 03:57 PM
texlurch's Avatar
You need the crossmember from a T56 car, and some people use a 1-1/2" spacer also to get the angles correct.
Old Nov 3, 2002 | 04:14 PM
cenman's Avatar
the 4l60e crossmember and a custom spacer is usually used. i dont know if the 4l60e and 700r4 crossmembers are that much different. people use the t56 crossmember for th400 swaps. another option would be to get the bmr crossmember for the th350.
Old Nov 3, 2002 | 04:39 PM
Stephen 87 IROC's Avatar
The TH350 rear mount sits 2" forward from the A4 mount. Weld a mounting pad extension onto the crossmember and drill some new holes in it.
Old Nov 3, 2002 | 05:21 PM
sseeya's Avatar
Thanks guys!
Old Nov 3, 2002 | 08:47 PM
GUMP's Avatar
BMR has a bolt in cross member that is quite nice. You can also use a factory automatic crossmember and the trans mount from the B & M kit for a 1982-92 F-body.
Daren
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Chris Anderson
Jan 27, 2015 08:30 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 12, 2014 10:51 PM
PROSTREET406
Jul 23, 2002 08:20 PM
