whats all entailed in running a 100 shot??
Old Nov 2, 2002 | 02:58 PM
justinZ28's Avatar
i was just wondering what is all needed to run a 100 shot on stock bottom end?? i was thinking of running full bolt-ons and a a4 w/2600 conveter with a performance rebuild, am i going to runs into rear end problems?? how long will the engine last if i run it on the regular?? what fuel system upgrades will i need?? and a guestamate of what it would run would be awesome. thanx for all the help guys
justin
Old Nov 2, 2002 | 09:07 PM
Z28ROC's Avatar
Most Lt1s can run a 100 hp shot safely on the stock pump.Hook up a fuel pressure guage and see if you get a pressure drop. An aftermarket ignition with rev limiter is highly recommended. colder plugs. Fuel pressure safety switch, and rpm window switch are also a good idea. A monitoring system, such as the LT1 scanmaster are also very handy.
Otherwise hook it up and go! Your engine will be fine.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
