Found some programming hardware sites
Old Feb 1, 2006 | 07:41 PM
BlackDog's Avatar
Was cruzin the web and found these 2 sites of hardware that we might need some day.
Just thought I'd share it with everyone.
T16-002 interface has a male pin OBD2 connector on one end and a female pin DB9 on the other and is also opto-isolated. You can connect it to your PC using a straight through RS232 cable.
http://www.multiplex-engineering.com/interfaces.htm
They sell OBD2 connectors and nothing else. The technical name of this plug is
J1962. So it could be callled the obd2, obd-2, Obd-II, Obdii or J1962 connector. They sell the female and male connector. The male plug is use to connect to your car computer and the female is for making an extension cable or some other apparatus.
http://www.carplugs.com/index.html
AdsoYo
May 2, 2018 03:21 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
