400
Old Jan 31, 2006 | 10:16 PM
cbrakllr88's Avatar
400
whts up? i was wondering abouth 400 trannys. I blew my 4l60-e and decided to go with a tubo 400 reverse valve body 3speed. I got up in to the car and it was longer than the stock tranny and the bellhousing blots did not match up. Is it worth it I will be needing an upgraded tranny soon but my main goal is to run 9's would I be good with a built 400? What would I need to do to have it fit into my z. By the way its an LS1 if that makes any difference. Or should I just go with a stage3 4l60-e? any help is greatly appreciated.thanks.
Old Jan 31, 2006 | 10:35 PM
blackztpi's Avatar
Re: 400
unless you are completely sold on having fun in the quarter only, go with the 4l60. having a lockup converter and an overdrive is very nice for the streets. the 4l60's can be built well to handle a lotr of power. yes, a th400 is a stronger unit out of the box, but you lose a lot of true streetability. by true streetability i mean much better gas mileage and less noise on ope road driving thanks to a lockup converter and another gear.
Old Feb 1, 2006 | 11:25 AM
cbrakllr88's Avatar
Re: 400
thanks for the input, yup its my d.d. but I just didnt know if a 60-e could handle 800-900 hp. but I guess it could.thanks for the help.
Old Feb 1, 2006 | 12:13 PM
12SCNDZ's Avatar
Re: 400
CPT "Pro Race" 4L60E.
Frank
Old Feb 1, 2006 | 12:15 PM
Cmr0z28's Avatar
Re: 400
What's up man? I see you're in Jupiter...are you on www.pbfbody.com ?
Anyways, I would highly recommend ^Frank's transmission. I'm very happy with mine.
Old Feb 1, 2006 | 09:25 PM
blackztpi's Avatar
Re: 400
well, correct. btw, you don't need 800-900 hp to run 9's
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Kawi
Sep 28, 2015 09:01 AM
Z Power
Sep 19, 2015 11:19 PM
