Will it fit?
Old Jan 29, 2006 | 07:50 PM
matLT1's Avatar
Will it fit?
I need a new set of tires for my Camaro. I still have the stock rims on it which I'd rather not replace. What I'm looking at are some GoodYear Eagle GT II's, with a wider tire in the rear than the front (I'm sticking with the 245's in the front). My question(s) to you guys is are these any good and will the tire I have posted below fit the stock rim and wheel well? Thanks
http://store.summitracing.com/defaul...031011&FROM=MG
Old Jan 29, 2006 | 10:29 PM
Re: Will it fit?
That 285/60-16 tire is 29.4" diameter - almost 4" larger in diameter than your stock tire - and will not fit in the wheel opening without a cutting torch or a can opener. The diameter shown on the Summit website (26.4") is incorrect. Go to Tire Rack, and look up the same tire.
If you managed to fit it in the rear, its going to be so large that it will make your car feel like you swapped the 2.73's out for a 2.38 gearset - think about it.
In addition, the Eagle GT2 is an "all season" tire - i.e. mud and snow rated. That is not going to be up to the level of tire that your car needs for aggressive driving.
That's the problem with 16" wheels..... the widest true "high performance" tire you will find will be a 255/50-16. If you really want a mid-grade all-season tire, look at the BFG Radial T/A. I think they might make a 275/50 or 285/50-16, that will only be a little bit too large for your car.
Old Jan 30, 2006 | 12:40 PM
Dave '97 Z28 M6's Avatar
Re: Will it fit?
Yes, unfortunately, a decade (or more) ago there was a lot better variety of wide tires for 16". Now 17" has become the "standard", with huge widths available.
As Injuneer wrote, 255/50-16 is as good as it gets for high performance 16" tires.
Old Jan 30, 2006 | 07:41 PM
matLT1's Avatar
Re: Will it fit?
Thanks guys, I didn't realize til after I had completed the post that Summit had screwed up with their calculations (definitely don't need a swamper ).
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
