Upper Radiator hose - Extremly frustrated
Old Jan 24, 2006 | 05:52 PM
defbear's Avatar
I replaced my water pump and all hoses about 8 months ago. The upper hose (the one on the driver side!) would trickle some anti-freeze every few days. I cut the hose, used 2 clamps, slide the hose back an forth, tried different clamps all to no avail. I then globbed some silcone all over the pipe and slid the hose on. This worked for about 6 months until it started trickling again. I came to the conclusion that the O-ring where the pipe is pressed in was leaking so I JB welded the pipe right where it goes into the pump. I even replaced the hose again. It was fine for a week, AND NOW ITS LEAKING AGAIN!!!!
I'm now convinced the anti-freeze is just SOME how getting past the clamp. Which by the way are the screw driver kind NOT the factory ones. Has anyone experienced anything like this? Should I stick with the factory pain in the *** clamps? Any advice/info would be GREATLY appreciated.
Old Jan 24, 2006 | 08:59 PM
Kataklysm's Avatar
Re: Upper Radiator hose - Extremly frustrated
Is the radiator cracked and just dripping down the hose?
Old Jan 24, 2006 | 09:42 PM
defbear's Avatar
Its actually coming out of the end that goes to the water pump. I'm convinced its just getting past the clamp somehow. I'm gonna mess with it tomorrow.
Fatdog2
Apr 27, 2015 10:32 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
