Which Window Switch??
Old Jan 22, 2006 | 02:42 PM
"White Knight"'s Avatar
NEX-18959 "NX RPM WINDOW SWITCH"
NEX-18959M "NX RPM WINDOW SWITCH FOR SINGLE COIL PER CYLINDER"
This just got me thinking that I have the Delteq system, which isn't the single coil per cylinder, but made me start thinking--- will the standard window switch work for me? What is used to trigger it? just a tach source right?
Old Jan 22, 2006 | 11:34 PM
Nitro Dave's Avatar
Re: Which Window Switch??
Use this one...
It will work. The tack signal is what trigers it. Or you can go off the negative side a coil.
Read the features on this bad boy...
http://www.nitrousoutlet.com/outlet/...section_id=137
Old Jan 22, 2006 | 11:58 PM
AF96Z28's Avatar
Personally, I like my MSD digital window switch.
Old Jan 23, 2006 | 12:45 AM
Nitro Dave's Avatar
Yes we carry the MSD also. But I like the unit above better.
Dave
Old Jan 23, 2006 | 01:40 AM
AF96Z28's Avatar
it does look a little smaller than the msd
Old Jan 23, 2006 | 04:02 PM
That looks like a pretty good unit.
Old Jan 23, 2006 | 04:06 PM
nosfed's Avatar
I don't think you can beat the Mallory 685. It does about everything you would ever need and only costs a hair over two hundred dollars.
Old Jan 23, 2006 | 08:48 PM
buzz12586's Avatar
Originally Posted by Nitro Dave
Use this one...
I was looking at that one for when I pick up my kit. Seems small and gets the job done.
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
