A4 to M6 swap
Old Jan 19, 2006 | 11:37 PM
scottslt1z28's Avatar
A4 to M6 swap
I am about to buy a built T56 to do a A4 to M6 swap in my Z
my question is.
Pcm retuned
new master cylinder
new slave cylinder
pedal set
What else will i need besides the for-mentioned
will i need a new wiring harness for a m6?? or does the A4 have a manual provision for it?
also what else will i need to do everything??? is the drive shaft a different length??.....etc.etc.
thanks guy, Scott
Old Jan 19, 2006 | 11:48 PM
Jameslt1TA's Avatar
Re: A4 to M6 swap
Im pretty sure you shouldn't need a diff wiring harness since the computer doesnt control the shifts.
Old Jan 20, 2006 | 09:38 AM
rngilliland's Avatar
Re: A4 to M6 swap
http://www.afrashteh.com/tranny_pics/T56.htm
You will need a 6spd program for the PCM. I see you have pcmforless tuning. I'm sure they can do it. I did mine with tunercat.
If you are not getting a complete swap kit you will need.
Crossmember
Torque arm mounts
Pigtails for vss, reverse lights, reverse lock out and the clutch switch on the pedals.
Rubber boot that attaches to trans tunnel.
6spd insert for console.
U bolt for clutch master cylinder.
Probably some other stuff I haven't thought of.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
