4:10 brands?
Old Dec 21, 2005 | 06:27 AM
ricekilla2000's Avatar
4:10 brands?
im looking at finnaly getting gears for my car. I wanna get 4:10 but not sure of the best brands being richmond gears or what? Will Eaton Diff do me well?
Old Dec 21, 2005 | 08:39 AM
Capn Pete's Avatar
Re: 4:10 brands?
I've got a set of Richmond 4.10's for my Z28 and they've held up thus far. They're also much quieter (much, much quieter in fact) than the set of Richmond 3.73's I previously had. From my experience, friends', and reading on here, it seems real hit & miss with Richmond and other brands for whining gears. Strange and Motive are a couple other common brands for gears for our cars.
Old Dec 21, 2005 | 02:14 PM
wrd1972's Avatar
Re: 4:10 brands?
Typically the Richmonds are noisy, but they are very robust.
The motives are not real bad if installed right, the ones I put in were still kind of noisy.
The OEM type like GM or Yukon are two cut gears with .003 backlash and if set up right are quiet. These are the types of gears in factory GM rearends.
I put the Yukons that are identical i'm told to GM in mine and I can barely hear them plus they have an anything goes warranty and Randys, you bust them they replace them.
I think most people agree that it is near impossible to install 4.10's in a GM 10 bolt and have it dead silent. A lot of it will depend on the install precision and attention to deatil and spec.
Old Dec 21, 2005 | 04:03 PM
Re: 4:10 brands?
thank you very much i think i know what im going to get now. will eaton spool do me fine?
Old Dec 21, 2005 | 05:24 PM
wrd1972's Avatar
Re: 4:10 brands?
I hope you are not driving with a spool on the street!
Old Dec 21, 2005 | 06:58 PM
Capn Pete's Avatar
Re: 4:10 brands?
You DO KNOW what a spool is, right?? I've got my doubts, because if you're getting a spool, that tells me you're SERIOUS about RACING your car, and if you're SERIOUS about RACING, then you shouldn't be wasting your time putting gears into the factory 10-bolt .
Likely an Eaton POSI is what you're looking for?
Old Dec 21, 2005 | 08:48 PM
Re: 4:10 brands?
my brother inlaw put a eaton spool in his 98 z-28 with 3:73 gears and never had any problems i do take the car to the track and it is not my everyday driver
Old Dec 31, 2005 | 09:35 AM
96DubyaS-6's Avatar
Re: 4:10 brands?
Not to highjack this. But i just bought some 3.73 motive gears. Part number 26036813 AAM does anyone know if this is the 2 cut that you're talking about. Im pretty sure it is.
Old Dec 31, 2005 | 10:37 AM
95camarolt1's Avatar
Re: 4:10 brands?
I have precision 4.10's
Old Dec 31, 2005 | 10:58 AM
remaxracer45's Avatar
Re: 4:10 brands?
what posi unit comes in the 96 ws6? which unit is the best if installing 410s on a 6 speed?
Old Jan 1, 2006 | 02:23 PM
Capn Pete's Avatar
Re: 4:10 brands?
AFAIK, the SS's and WS6's always got the Auburn units, but someone please correct me if I'm wrong! I know that in the later years (ie: '02) the Torsen was standard, but the Auburn was offered with the SS package.
As far as which one is best for a 6-speed? Well, technically "neither one" if it's just a 10-bolt!!
The Auburns can wear out, while a Torsen will either work or it won't (which means it's broken! ) since they have a whole pile of worm gears and such inside them. The Auburns work on hydraulic and spring pressure.
Old Jan 1, 2006 | 10:16 PM
Re: 4:10 brands?
so what you are saying unless you are changing rears stay with the auburn that came in it? what if I can get a torsion cheap?
Old Jan 2, 2006 | 01:02 PM
Capn Pete's Avatar
Re: 4:10 brands?
I prefer the Auburn, but that's just me. Like I said, they were only offered with the SS "performance package" in '02, so that makes me think they're better too. The work more like a traditional (clutch pack) posi. The Torsens are ok I guess? More clunking from it though.
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
DETROIT_AREA_00_SS
Aug 14, 2002 08:00 PM
