battery storage question
Old Dec 15, 2005 | 08:28 AM
flusz28's Avatar
okay i have a battery tenderizer that i use. my garage is not insulated so it does get kinda cold in the winter. now my last battery was old but didn't get much use and sat for like almost a year in the charger. well the battery had a low charge pretty often. alternator checked out good.
question is- should i first not keep the battery on the tenderizer all the time?
should i keep the battery inside my house in the basement on a table and not charge it?
should i keep it in my basement on the table and keep it chargeing?
Old Dec 15, 2005 | 09:00 AM
Re: battery storage question
The whole purpose of the Battery Tender is to be kept on your battery full-time, to keep it in the perfect state of charge. I keep my Formula in an unheated garage, with the battery connected to the car, and the Battery Tender connected to the battery full-time. The battery is always ready to start the car, but it not being damaged by the over-charging you would get from a conventional battery charger.
I can't see any advantage in putting the battery in a heated area.... "cold" probably slows down the reactions that eat up the battery plates.
Old Dec 15, 2005 | 09:09 AM
flusz28's Avatar
i always pull mine out and put in on my work bench. my buddy has a 05 GTO and on there GTO website guys told him to just keep it somewhere warm and don't put it on any type of charger and it will be fine. i was like ah... maybe if it was brand new and never used,like sitting on the shelf at the store i would agree with that. it has been a month and he has not started the car or messed with his battery. the cost of a battery compared too $20.00 for the tenderizer would make my mind up
Thanks Fred
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
nosliw
Feb 7, 2015 01:30 PM
capebuf
Jan 13, 2015 07:22 PM
97z28k&N
Jan 9, 2015 04:58 AM
nophix
Nov 30, 2014 10:26 PM
