Reusing diff and tranny fluid?
Old Dec 13, 2005 | 11:55 PM
MustangEater82's Avatar
so what are your guy's thoughts on reusing tranny fluid and diff fluid?
just put new stuff in both like 2-3k miles ago. Trans broke, I drained the fluid it looked clean but its in one of those(you can see in) drain pans. Thinks its worth reusing? dump it into a clear container, to see if any funky metal is in it, then redump into the new trans?
Also for diff, no problems, but swapping the entire 10-bolt, and a few internal parts. Can I swap reuse the fluid.
woudl be using new never used drainpans for each.
normally I wouldn't mind but its like $25-45 worth of fluid. Figure its worth asking.
Old Dec 14, 2005 | 01:01 AM
Birdman7389's Avatar
Re: Reusing diff and tranny fluid?
I say its not worth the chance, don't risk your $$$ rebuilt trans over a couple bucks in fluids.....
Old Dec 14, 2005 | 06:45 AM
12SCNDZ's Avatar
It's only $24 for a case of new transmission fluid. Why would you even think about reusing the old stuff? If the old transmission went, it has most definitely contaminated the fluid.
Frank
Old Dec 15, 2005 | 03:26 AM
smoknta's Avatar
Not worth it.
Old Dec 15, 2005 | 05:53 AM
Cmr0z28's Avatar
Originally Posted by smoknta
Not worth it.
+1.
Old Dec 15, 2005 | 07:01 AM
rskrause's Avatar
Moderator
Absolutely not. You will screw up your new parts.
Rich
Old Dec 15, 2005 | 07:03 AM
Javier97Z28's Avatar
Moderator
Originally Posted by Cmr0z28
+1.
+9..
worst idea i've ever heard.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
