rear end swap ?
Old Dec 13, 2005 | 12:46 AM
xdamxincx's Avatar
rear end swap ?
will a rear end from a 3rd gen (iroc) bolt in to a 4th gen or does it need modifications?
Old Dec 13, 2005 | 04:30 AM
RE AND CHERYL's Avatar
Re: rear end swap ?
There are differences in the brakes and parking brake, but they are otherwise the same (with the exception of the 9 bolt)
Old Dec 13, 2005 | 05:26 AM
Dave89IROC's Avatar
Re: rear end swap ?
third gen is 4 inches shorter, so wheels won't fit........
Old Dec 13, 2005 | 09:55 AM
xdamxincx's Avatar
Re: rear end swap ?
different offset rims should fix that or some mini tubbing ... is it a direct bolt in tho ?
thanks for the reply too.
Old Dec 13, 2005 | 05:30 PM
Re: rear end swap ?
OPS! my bad
Old Dec 14, 2005 | 03:02 PM
Re: rear end swap ?
The spring, shock, torque arm and panhard rod mounts are identical. The brake mounts will be different. The e-brake provisions will be different. There will not be a sensor (or sensors) for ABS/TCS. The brakes may be so far inboard that you could have problems with them being too close to things like the jounce bumpers, although that's maybe overly cautious.
There's a dimensioned drawing on the Strange site that shows the difference is 3" in overall width. You could use a 1.5" bolt on adapter (like the ones from Skulte Performance, not smiple plates) for the wheels.
http://www.skulte.com/
Old Dec 14, 2005 | 03:19 PM
1SlowFormula's Avatar
Re: rear end swap ?
Fred according to this, skulte makes the 2 inch adapter for that purpose...
Old Dec 14, 2005 | 03:35 PM
Re: rear end swap ?
I understand that the difference may be 2"... I'm just pointing out that when Strange builds "bolt-in" rears for the 3rd Gen, they make them 3" narrower than the ones for the 4th Gen. It would seem worthwhile to investigate the correct number.
Old Dec 14, 2005 | 03:46 PM
Dave89IROC's Avatar
Re: rear end swap ?
the difference is between 3" and 4", but if he does it, he will need to verify on the car, for wheel fitment
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
