Difference between LS1 and LT1
Old Dec 11, 2005 | 09:38 PM
surf121's Avatar
Hey guys I'm new here and was just wondering what's the difference between the LS1 and LT1? I know they are different engines and all but what are the advantages, disadvantages, etc. of each? Thanks.
Old Dec 11, 2005 | 09:44 PM
Need4Camaro's Avatar
Re: Difference between LS1 and LT1
Difference? The whole thing... Completely different blocks...
Not to bash the LT1 guys but STOCK FOR STOCK... the LS1 is just alltogether a better engine.
LT1's biggest flaw is the Opti Spark. Wet it and your driving days are abrubtly put to an end.
LS1's flaw I believe is the Piston Slap but thats not exactly too common I believe.
Old Dec 12, 2005 | 07:19 AM
Kraest's Avatar
Retired
After owning each, I can't think of a single advantage the LT1 has over the LS1.
There's a sticky thread on top of the forum describing the LS1 motor that you should read to compare to the LT1. Also, you can search for older articles that introduce the LS1 as a new motor and describe what was upgraded (aluminum block, 15* heads, coil-per-cylinder, composite intake manifold, etc, etc, etc.)
Mike
Old Dec 12, 2005 | 07:35 AM
PhantomTA's Avatar
Moderator
Please do a search and read the sticky info at the top of this forum.
rideordie
Nov 5, 2019 04:52 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
Aneurysm
12
Sep 10, 2002 05:21 PM
