Guys with ProTorque converters inside....
Old Nov 27, 2005 | 12:05 PM
Cmr0z28's Avatar
I'm running a 3200 10.5" lockup Protorque converter.
I was wondering what would be the best launch technique to get out of the hole hardest on motor and a 100 shot. 12-bolt is going in next week, so don't worry about my rear
Old Nov 27, 2005 | 05:37 PM
rskrause's Avatar
Moderator
Re: Guys with ProTorque converters inside....
You need to experiment. Try some different things, keep a log so you can analyze the results.
Rich
Old Nov 27, 2005 | 07:34 PM
12SCNDZ's Avatar
Matt,
What's the car footbrake stalling at? I come out at footbrake stall. Alot of it also depends on your traction situation.
Frank
Old Nov 27, 2005 | 07:42 PM
Cmr0z28's Avatar
The tires break loose around 2400-2500 RPM's. I tried launching at 2,000 with my other tires, and I got bad wheel hop (I guess because the suspension was loaded beforehand). I haven't tried it yet on the Mickey Thompsons, so I'll give it a shot.
Also, is it safe to flash the stall on a 100 shot, or should I set my window switch higher?
Old Nov 27, 2005 | 09:15 PM
rskrause's Avatar
Moderator
The car will start to move against the brakes or just start spinning the rears if you try to stall the converter against the brakes. Like I said, it's going to require some trial and error. In the end, most of what you learn will be negated when you change the equation by swapping in the 12-bolt, so really don't sweat it.
Rich
Old Nov 27, 2005 | 10:10 PM
Cmr0z28's Avatar
Rich
Well, the car is down until the 12-bolt is in, so we don't need to worry about knowledge being negated
Basically what I'm saying is, if I tried to launch at a higher PRM, when I launched, I got wheel hop. When I went off idle/1000/1200 RPM's, I never had the problem.
ChrisFrez
Feb 15, 2015 07:49 AM
joe777107
Dec 1, 2014 09:32 AM
Red97LT1
Aug 7, 2002 05:45 PM
