After swapping to an OBDI conversion computer....
Old Oct 28, 2002 | 05:27 PM
Dan K's Avatar
has anyone noticed that they can't run as much timing @ WOT?
I logged a couple of runs w/ Autotap before I swapped to my OBDI conversion and if I remember right I could run about 36-38 degrees and no knock.
Now after converting to an OBDI pcm setup to use the OBDII knock sensor, I can only run 33-34 degrees.
Not sure if it makes a difference hp wise, but seems odd anyways.
Anyone else had a similiar situation using the OBDI ks with the conversion computer?
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
