car running rough after plug change!
Old Nov 13, 2005 | 04:17 PM
camarokid24's Avatar
I gapped my AC delco r42lts to .035 as I am running N20. I used the little wheel gauge that I got from Autozone. The car seems to be running rich. It nearly wants to die at stop lights. Could the gap size be causing the rough idle? Any help guys would be greatly apriciated. I am going to leave the plugs in till this weekend as it is dark now and it took me a long time to change them. Thanks AJ
Old Nov 14, 2005 | 10:42 AM
LWillmann's Avatar
Re: car running rough after plug change!
When I ran some Autolite 104's gapped to .035 (I used a feeler to gap mine), my car would miss at idle, but ran fine otherwise.
Putting NGK TR-55's gapped at .035 fixed the miss at idle.
So I'm currently running TR-55's gapped at .045 rather than .050.
Old Nov 14, 2005 | 10:53 AM
sabre81's Avatar
I would recommend NGKs as well. Try a slightly larger gap (.40 or .45)
Good luck
Old Nov 14, 2005 | 02:25 PM
izzyz28's Avatar
Aren't the R42's about three steps colder than stock(R45's I believe)? If so then that could be your problem. I've used various plugs and plug gaps in my car and never had a problem whether they were gapped at .035" or .050".
Old Nov 15, 2005 | 09:43 PM
Thanks for the info guys I picked up some autolite 104's today. I hope these will do the trick
bfmv13trivium
Jan 14, 2015 09:57 AM
ro2207
Dec 4, 2014 06:18 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Brent94Z
Mar 21, 2002 04:44 PM
