slp ram airbox question
Old Nov 7, 2005 | 03:08 PM
sc1twntrbo's Avatar
will the slp ram airbox for the ultra z hood fit a stock ws6 hood? i figure it would but would like a more def answer before i spend $300
Old Nov 7, 2005 | 03:31 PM
Re: slp ram airbox question
The SLP online catalog shows the same part number for both the Ultra-Z and the Ram Air HO airboxes, and indicates it works with both hoods:
http://www.slponline.com/view_product.asp?P=100008
The SLP airbox is dimensionally identical to the stock WS6 airbox, lacking only the "Pontiac" and "Ram Air" logos, and does not come with the pre-molded gasket for the lid. They include some sticky-tape weatherstripping instead.
I've compared my SLP box to a genuine WS6 box, side by side, and they are identical, except as noted above.
Old Nov 7, 2005 | 03:56 PM
sc1twntrbo's Avatar
thanks ill go ahead and order one
Old Dec 11, 2005 | 04:44 PM
sc1twntrbo's Avatar
i finally got my new airbox in and i already got rid of my old one. without the rubber peices on it it seems like its already hitting the hood. is this normal? if i look through the nostrals i can see the front of the box but i cant see the airfilter. is this normal?
Old Dec 11, 2005 | 10:06 PM
It shouldn't be hitting the hood. Its normal to see the front of the filter box when you look in the grills.
Old Dec 12, 2005 | 12:53 AM
sc1twntrbo's Avatar
but thats all i see i got the hood secound hand and its gutted. so i can reach in and hit only box. in order to get to the top of the box the air would hit it and then go up and squeeze inbetween part or the hood that comes down and the filter box. do you have pics of the back side of the inlet of the hood?
thanks for helping
Old Dec 12, 2005 | 06:25 AM
I have pictures, but the server that they are on is down for some reason.
Do you want a picture of the inside of the hood near the scoop? I can e-mail you that if you do.
I know the box on my car sits a bit high, because of the Griffin radiator. We had to cut a bit off the bottom of the plastic upper radiator support bracket, then screw the bracket directly to the top of the radiator. Even with that, I have the seal strips on the hood, and they just contact the top of the box when the hood closes.
Old Dec 12, 2005 | 09:08 AM
sc1twntrbo's Avatar
i was wanting a pic of the back side of the hood. looking into the nostrals from the rear of the car forward. i just wanna see if my hood is cut high enough up. my email is sc1twntrbo@yahoo.com thanks for all the help
Old Dec 12, 2005 | 06:16 PM
QuickSilver02's Avatar
This is kinda unrelated to your posts, but I have an SLP airbox in my SS and it rubs against the bottom of the hood. I wonder if they just made them a tad too high cuz my stock one didn't rub.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rjc1629
Jan 27, 2015 10:46 AM
GigaMp3z
Feb 20, 2003 02:57 PM
