Why does it take so long to boost my Firebird?
Old Oct 23, 2005 | 01:22 PM
IRONFIST's Avatar
Whenever I try to boost my 'bird it takes forever... even if I disconnect the battery or switch batteries. Is it because I'm always using a small car to boost it? Does that make a difference?
Just asking because I'm sitting here waiting for my Cavalier to boost my 'bird... I'm thinkin it'll take a good 45 mins
Old Oct 23, 2005 | 01:32 PM
myslowcamaro's Avatar
Re: Why does it take so long to boost my Firebird?
possible something is draining the battery as its charging.
Old Oct 23, 2005 | 02:42 PM
IRONFIST's Avatar
That's what I thought at first so I took the battery right out of the car, and tried to charge it. It does charge, and holds a charge... just curious why it takes so long.
The one variable I hadn't looked at... and that I suspect now that I've looked closer is crappy booster cables, I think they have too much corrosion on them.
Old Oct 23, 2005 | 03:08 PM
Dave89IROC's Avatar
2 possiblities, slow/low charge rate(could be lower output from the boosting vehicle, or corrosion on your cables) or, the deader your battery is, the longer it will take, I.E., if you need 400 amps to start, and the batt only has 300, you only need 100 to start it, but if your batt only has 100, you get the picture
Old Oct 23, 2005 | 10:46 PM
GoFast908Z's Avatar
Member
try an Optima Yellow top if you need a new battery. Never had to recharge it since i bought it. And i'm VERY used to recharging batteries. LOL
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 12, 2014 10:51 PM
